  • 16x 2.5G PoE++ ports incl. 8x Neutrik etherCON connectors with 4x 25G SFP28 uplinks
  • Two internal 800W power supplies providing 530W of redundant base PoE budget
  • Switch ships with one APM414V interface card with 4x 25G SFP28 ports
  • Optional APM414C Interface Card with 4x 10G RJ-45 ports
  • Optional APM414SD Interface Card with 2x Neutrik opticalCON DUO connectors for 4x MMF transceivers
  • Optional APM414LD Interface Card with 2x Neutrik opticalCON DUO connectors for 4x SMF transceivers
  • 2x Neutrik powerCON connectors and C14 male power cord adapters for standard IEC 320 C13 cords
  • NETGEAR IGMP Plus™, NETGEAR AV OS™, and NETGEAR Engage™ Controller speed up AV installations
  • SMPTE ST 2110 Grandmaster Clock and Boundary Clock for AES67 and ST2059-2 applications
  • Multi-color LED on each physical port reflecting the profile color in the NETGEAR AV OS™ and Engage Controller
  • NETGEAR ProSAFE® Limited Lifetime Hardware Warranty
  • Lifetime Next Business Day Hardware Replacement
MSM4320 MSM4320-100NES MSM4320-100NES
NEW
NETGEAR M4350-16M4V Fully Managed Switch (MSM4320) armor
16x 2.5G PoE++ (530W base, up to 1,130W) incl. 8x Neutrik etherCON and 4xSFP28 25G Managed Switch armor
NEW
We're always here to help
Want a custom configuration?
Need to check compatibility?
Ready for a quote?
Our experts are available via online chat, phone, or email.
Join Waitlist
Successfully registered.
M4350 Power and Throughput m4350 Power And Throughput
POWER AND
THROUGHPUT
Edge to core flexible platform, from 1 Gigabit to 100 Gigabit, good for projects of all sizes.
M4350 AV OVER IP SIMPLIFIED M4350 AV OVER IP SIMPLIFIED
  • Groundbreaking AV GUI
  • Multicast in an Instant
  • Sleek, Quiet Design
  • Automatic Configuration
M4350 FAST, EASY CONFIGURATION M4350 FAST, EASY CONFIGURATION
FAST, EASY
CONFIGURATION
FOR AV PROS
FOCUS ON THE EVENT
NOT FAN NOISE
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
With built-in NETGEAR IGMP Plus™, there's little-to-no setup required for flawless audio and video delivery. Enable multicasting right out of the box.
COMPARE M4350 SERIES SWITCHES
MSM4320
MSM4320
csm4316-shadow-front-tipoff
CSM4316
SWITCHES_M4350
GSM4328
SWITCHES_M4350
GSM4352
MSM4310
MSM4310
CMS_Tech_Specs_Image-MSM4310_P_NoShadow
MSM4332
msm4328f
MSM4328F
XSM4344FC_transparent_compareswimlane
XSM4344FC
SWITCHES_M4350
MSM4352
SWITCHES_M4350
XSM4316
SWITCHES_M4350
XSM4324
SWITCHES_M4350
XSM4328CV
SWITCHES_M4350
XSM4328FV
SWITCHES_M4350
XSM4340CV
SWITCHES_M4350
XSM4340V
SWITCHES_M4350
XSM4340FV
SWITCHES_M4350
VSM4320C
SWITCHES_M4350
XSM4344C
# Total Ports
# Total Ports
20
# Total Ports
16
# Total Ports
28
# Total Ports
52
# Total Ports
10
# Total Ports
32
# Total Ports
28
# Total Ports
44
# Total Ports
52
# Total Ports
16
# Total Ports
24
# Total Ports
28
# Total Ports
28
# Total Ports
40
# Total Ports
40
# Total Ports
40
# Total Ports
20
# Total Ports
44
Port Types
Port Types
16x 2.5G PoE++ incl. 8x Neutrik etherCON, 4x 25G SFP28
Port Types
16x100G QSFP28
Port Types
24x 1G, 4x SFP+
Port Types
48x 1G, 4x SFP+
Port Types
8x2.5G, 2x25G SFP28
Port Types
24x2.5G, 4x10G, 4x25G SFP28
Port Types
24xSFP+, 4x10GBASE-T/SFP+
Port Types
40x10G SFP+, 4x100G QSFP28
Port Types
44x 1G/2.5G, 4x 1G/2.5G/5G/10G, 4x SFP28 (25G)
Port Types
8x 1G/2.5G/5G/10G, 8x SFP+
Port Types
12x 1G/2.5G/5G/10G, 12x SFP+
Port Types
24x 1G/2.5G/5G/10G, 4x SFP28 (25G)
Port Types
24x SFP+, 4x SFP28 (25G)
Port Types
36x 1G/2.5G/5G/10G, 4x SFP28 (25G)
Port Types
24x 1G/2.5G/5G/10G, 8xSFP+, 8x SFP28 (25G)
Port Types
32x SFP+, 8x SFP28 (25G)
Port Types
16x SFP28 (25G), 4x QSFP28 (100G)
Port Types
40x 1G/2.5G/5G/10G, 4x QSFP28 (100G)
Total PoE Budget
Total PoE Budget
530W -> 1,130W
Total PoE Budget
Total PoE Budget
648W –> 720W
Total PoE Budget
236W -> 1,440W
Total PoE Budget
119W -> 551W
Total PoE Budget
552W -> 2,520W
Total PoE Budget
Total PoE Budget
Total PoE Budget
194W -> 3,314W
Total PoE Budget
Total PoE Budget
Total PoE Budget
576W -> 720W
Total PoE Budget
Total PoE Budget
280W -> 1,760W
Total PoE Budget
290W -> 1,770W
Total PoE Budget
Total PoE Budget
Total PoE Budget
196W -> 1,676W
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
24
# PoE+ Ports
48
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
24
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE++ Ports
# PoE++ Ports
16
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
8
# PoE++ Ports
24
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
48
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
36
# PoE++ Ports
24
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
40
Rack Mount
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
FORM FACTOR W X H x D (MM)
440x432x43.2
440x400x43.2
440 x 400 x 43.2
440 x 400 x 43.2
220x300x43.2
440 x 400 x 43.2
440 x 400 x 43.2
440x400x43.2
440 x 400 x 43.2
220 x 400 x 43.2
220 x 400 x 43.2
440 x 400 x 43.2
440 x 400 x 43.2
440 x 400 x 43.2
440 x 400 x 43.2
440 x 400 x 43.2
440 x 400 x 43.2
440 x 400 x 43.2
PRO AV FAMILY COMPARISON
M4250 SWITCH SERIES
M4350 SWITCH SERIES
M4500 SWITCH SERIES
USE CASE
USE CASE
Access/Edge
USE CASE
Core/Access/Edge
USE CASE
Core/Access/Edge
SWITCH STACKING
SWITCH STACKING
No
SWITCH STACKING
Yes
SWITCH STACKING
No (MLAG)
PoE CAPABLE
PoE CAPABLE
Yes
PoE CAPABLE
Yes
PoE CAPABLE
No
PORT SPEEDS
PORT SPEEDS
1, 2.5, 10Gbps
PORT SPEEDS
1, 2.5, 10, 25, 100Gbps
PORT SPEEDS
1, 10, 25, 100Gbps
AVB SUPPORT
AVB SUPPORT
Yes*
AVB SUPPORT
Yes
AVB SUPPORT
No
AV WEB UI / AV TEMPLATES
Yes
Yes
No
AV DESIGN
(FRONT LED'S & REAR CABLING)
AV DESIGN
Yes
AV DESIGN
No
AV DESIGN
No
M4350-16M4V Technical Specifications
MSM4320 MSM4320
Product Specifications
  • M4350-16M4V (MSM4320)
    1
  • Power Cord (Standard AC to C13)
    1
  • Neutrik powerCON connectors and C14 male power cord adapters for standard IEC 320 C13 cords
    2
  • Console USB Type-C cable
    1
  • Rack-mounting standard bracket set
    1
  • Set of longer brackets for recessed mounting
    1
  • Rubber footpads for tabletop installation
    4
  • Installation guide
    1
  • Width
    440mm
  • Depth
    432mm
  • Height
    43.2mm
  • Weight
    7.85kg (17.31lb)
  • Primary Port Speed
    2.5 Gigabit
  • Number of Ports
    20 (16 x 2.5G PoE++ incl. 8x Neutrik etherCON, and 4x 25G SFP28)
  • IGMP Support
    Enhanced (NETGEAR IGMP Plus™)
  • Jumbo Frame Support
    Yes, up to 12kb
  • AVB Support
    Yes, included
  • Acoustics
    Quiet Mode 35.6dB@25ºC
  • Power Consumption
    With max PoE:  1359.8W/4,639.64Btu/hr
    Without PoE:    109.6W/373.96Btu/hr
  • Standby w/o any port connection
    50.6W/170.60Btu/hr
  • PSU Compatible Models
    Internal only
  • Internal PSUs
    2 internal 800W PSUs with PowerCON connectors
  • Compatible Interface Cards
    APM414SD (2x Neutrik opticalCON QUAD for 4x MMF Transceivers)
    APM414LD (2x Neutrik opticalCON QUAD for 4x SMF Transceivers)
    APM414V (4x Standard 25G SFP28 ports) ships with the switch
    APM414C (4x Standard 10G RJ5 ports)
  • NETGEAR Engage Controller
    Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive.
  • This product is backed by a NETGEAR ProSAFE ® Limited Lifetime Hardware Warranty. Phone and chat technical support provided for 90 days from purchase date. This product comes with a limited warranty that is valid only if purchased from a NETGEAR authorized reseller, and covers unmodified hardware, fans and internal power supplies – not software or external power supplies, and requires product registration at https://www.netgear.com/business/registration within 90 days of purchase; see https://www.netgear.com/about/warranty for details. Intended for indoor use only.
