NETGEAR Essentials Switches featuring 8 ports of gigabit Ethernet. This switch is plug-and-play with unmanaged ports needing no additional configuration at full non-blocking performance. GS308v3 GS308-300NAS GS308-300NAS
Unmanaged Essentials Switch (GS308v3) armor
8-Port Gigabit Ethernet Unmanaged Essentials Switch armor
Join Waitlist
Successfully registered.
ETHERNET PORT CONFIGURATION
8 Gigabit ports
PLUG-AND-PLAY
FULL PERFORMANCE
SILENT OPERATION
ENERGY EFFICIENT
Designed to optimize power usage lowering its cost to operate.
Metal Case
Durable and Rugged
VERSATILE MOUNTING OPTIONS
Supports desktop and wall placement, and includes all mounting hardware in the box
STANDARDS-BASED DESIGN
Ensure interoperability with any standards-based PDs
Plug-and-play
Automatic connectivity to your router or modem of 4 or 7 additional wired connections. No need for an IT expert!
Mounting flexibility
Small and silent desktop form factor for quiet operation – Adapts to your needs and configuration in any environment
Energy efficient
Switches automatically adjust power consumption according to the link status and cable length.
gs308v3_tech_specs_image_1
gs308v3_tech_specs_image_2
  • Dimensions : 158 x 101 x 29mm (6.2 x 4.0 x 1.1in)
  • Weight : 0.39 kg (0.86 lb)
  • Model Description : NETGEAR 8-Port Gigabit Ethernet Unmanaged Essentials Switch (GS308v3)
  • Speed : Gigabit
  • Number of Ports : 8
  • Connector Type : Metal
  • Switch Housing : Metal
  • LEDs : Power, Link/Activity
  • Short cable power saving : Yes
  • Energy Efficient Ethernet Support (IEEE 802.3az) : Yes
  • Jumbo Frame Support : 9,216 bytes
  • MAC Table Size : 8K
  • Packet buffer size : 192k
  • DC Power Adapter : 12V / 0.5A
  • Max Power Consumption (Watts) : 3.04W
  • Acoustic Noise Level @ 25° C (dBA) : 0 dBA (Fanless)
  • Operating Temperature : 0° to 40°C (32° to 104°F)
  • MTBF (@ 25° C) : 3,711,898 hours
  • Electromagnetic compliance (A or B) : Class B
  • Form Factor : Desktop or wall-mountable
    • Warranty: These products are backup by a NETGEAR limited Hardware Warranty up to 3 years (depending on model and region).
  • Support : 24/7 basic technical support provided for 90 days from purchase date, when purchased from a NETGEAR authorized reseller.
