Easy Smart Managed Essentials Switch (GS316EPP)
16-Port High-Power PoE+ Gigabit Ethernet Easy Smart Essentials Switch (231W) with 1 SFP Port
The NETGEAR 16-Port High-Power PoE+ Gigabit Ethernet Easy Smart Switch delivers essential business networking features and powers PoE+ devices like VoIP phones, IP cameras, and more.
Gigabit Ethernet
16 ports provide up to 1000 Mbps of dedicated, non-blocking bandwidth eachPoE+ Support
15 PoE+ ports provide a total of 231W of power so you can power and connect your devices with a single wire.Advanced PoE Controls
Manage PoE prioritization, PoE power limit per port, PoE scheduling and more for simple control over all PoE-powered devicesNon-Blocking Switching
10Gbps (10/100/1000 Mbps) line rate fabric ensures congestion-free connectivity to your devices.Fanless Design
Silent operation makes this switch perfect for noise-sensitive environmentsVersatile Mounting Options
Install your switch on your desktop or mount it to your wall with the hardware provided in the boxTechnical Specifications
- Dimensions (W x D x H) : 286 x 102 x 27 mm (11.26 x 4.02 x 1.06 in)
- Weight : 0.88 kg (1.95 lb)
- Speed : Gigabit
- Total PoE+ Ports : 15
- Total PoE+ Budget : 180W
- Uninterrupted PoE : Yes
- Bandwidth : 32Gbps
- Max Mac Entries : 4K
- Buffer Size : 192KB
- Energy Efficient Ethernet (IEEE 802.3az) : Yes
- Priority Queuing : WRR
- Jumbo Frame Support : 10,000 bytes
