The NETGEAR 16-Port PoE+ Gigabit Ethernet Easy Smart Essentials Switch delivers essential business networking features and powers PoE+ devices like VoIP phones, IP cameras, and more. GS316EP GS316EP-100NAS GS316EP-100NAS
Easy Smart Managed Essentials Switch (GS316EP) armor
16-Port PoE+ Gigabit Ethernet Easy Smart Managed Essentials Switch (180W) with 1 SFP Port armor
Join Waitlist
Successfully registered.
GIGABIT ETHERNET AND FIBER
15 ports provide Gigabit Ethernet connectivity to your devices and 1 SFP fiber port for long distance connections
POE+ SUPPORT
15 PoE+ ports provide a total of 180W of power so you can power and connect your devices with a single wire
EASY POE CONTROLS
Manage PoE prioritization, PoE power limit per port, PoE scheduling and more for advanced control over all PoE-powered devices
VLANS
FANLESS DESIGN
VERSATILE MOUNTING OPTIONS
Place your switch on your desktop or mount it to your wall with the hardware provided in the box. Silent operation makes this switch perfect for noise-sensitive environments
Everest_GS316EP_PDP_Tech Specs Image 1
Everest_GS316EP_PDP_Tech Specs Image 2
  • Dimensions (W x D x H) : 286 x 102 x 27 mm (11.26 x 4.02 x 1.06 in)
  • Weight : 0.88 kg (1.95 lb)
  • Speed : Gigabit
  • Total PoE+ Ports : 15
  • Total PoE+ Budget : 180W
  • Uninterrupted PoE : Yes
  • Bandwidth : 32Gbps
  • Max Mac Entries : 4K
  • Buffer Size : 192KB
  • Energy Efficient Ethernet (IEEE 802.3az) : Yes
  • Priority Queuing : WRR
  • Jumbo Frame Support : 10,000 bytes
    • Warranty: This product is backed by a NETGEAR limited lifetime hardware warranty (depending on region). Click here for coverage, availability and terms and conditions.
    • Optional Next Business Day Hardware Replacement for duration of warranty (depending on region). Click here for coverage, availability and terms and conditions.
    • Support: ProSUPPORT 24x7 Advanced Technical Support via phone for 90 days (Remote diagnostics performed by our technical experts for prompt resolution of technical issues). ProSUPPORT coverage can be extended by purchasing 1, 3, or 5-year contracts.
    • GS316EP Support
We're Always Here to Help
download-circle-black
VISIT MY.NETGEAR.COM
community-black
NETGEAR COMMUNITY
question-mark-black
NETGEAR SUPPORT
