Easy to manage, fundamental network features at an affordable cost for SMBs. GS308EPP offers 123W total power budget to power devices PoE devices such as VoIP phones, IP cameras, wireless access points, etc. GS308EPP GS308EPP-100NAS GS308EPP-100NAS
Easy Smart Managed Essentials Switch (GS308EPP) armor
8-Port Gigabit Ethernet Easy Smart Essentials PoE Switch (123W) armor
Join Waitlist
Successfully registered.
Gigabit Ethernet
8 ports provide up to 1000 Mbps of dedicated, non-blocking bandwidth each.
PoE+ Support
8 PoE+ ports provide a total of 123W of power so you can power and connect your devices with a single wire.
Advanced PoE Controls
Manage PoE prioritization, PoE power limit per port, and more for simple control over all PoE-powered devices.
Non-Blocking Switching
10Gbps (10/100/1000 Mbps) line rate fabric ensures congestion-free connectivity to your devices.
Fanless Design
Silent operation makes this switch perfect for noise-sensitive environments.
Versatile Mounting Options
Install your switch on your desktop, or mount it to your wall or rack with the hardware provided in the box.
Tech-Specs-Image-1
Tech-Specs-Image-2
  • Dimensions (W x D x H): 158 x 101 x 27 mm (6.2 x 4.0 x 1.1 in)
  • Weight: 0.49 kg (1.08 lb)
  • Speed: Gigabit
  • Total PoE+ Ports: 8
  • Total PoE+ Budget: 123W
  • Uninterrupted PoE: Yes
  • Bandwidth: 16Gbps
  • Max Mac Entries: 4K
  • Buffer Size: 192KB
  • Energy Efficient Ethernet (IEEE 802.3az): Yes
  • Priority Queuing: WRR
  • Jumbo Frame Support: 9,216 bytes
    • Warranty: This product is backed by a NETGEAR limited lifetime hardware warranty (depending on region). Click here for coverage, availability and terms and conditions.
    • Optional Next Business Day Hardware Replacement for duration of warranty (depending on region). Click here for coverage, availability and terms and conditions.
    • Support: ProSUPPORT 24x7 Advanced Technical Support via phone for 90 days (Remote diagnostics performed by our technical experts for prompt resolution of technical issues). ProSUPPORT coverage can be extended by purchasing 1, 3, or 5-year contracts.
    • GS308EPP Support
We're Always Here to Help
download-circle-black
VISIT MY.NETGEAR.COM
community-black
NETGEAR COMMUNITY
question-mark-black
NETGEAR SUPPORT
