Easy to manage, fundamental network features at an affordable cost for SMBs. GS305EP offers 63 W total power budget to power devices PoE devices such as VoIP phones, IP cameras, wireless access points, etc. GS305EP GS305EP-100NAS GS305EP-100NAS
Easy Smart Managed Essentials Switch (GS305EP) armor
5-Port Gigabit Ethernet PoE+ Easy Smart Essentials Switch (63 W) armor
Join Waitlist
Successfully registered.
EASY MANAGEMENT
Plug-and-play Easy Smart switch fundamental network management features. No need for an IT expert or a complicated user manual, just configure your network with the user-friendly NETGEAR Web GUI
CONSUMER AND BUSINESS-FRIENDLY GUI
Easily manage and configure advanced features for your network simply through a responsive consumer and business-friendly web and mobile GUI
VLANS
COMPREHENSIVE QOS
Advanced controls for optimized network performance and better delivery of mission-critical traffic such as voice and video
MULTI-LANGUAGE SUPPORT
Context in 3 different languages (English, German, and Japanese)
PoE+ SUPPORT
4 ports PoE+ for a total of 63W of power enabling powering of all types of PoE devices with a single wire deployment of power and network connectivity to PoE+ devices such as wireless AP, IP cameras, VoIP phones, access-controlled security door locks or any other IoT PoE-powered devices
ADVANCED PoE CONTROLS
Power management of the PoE connected devices by enabling and disabling PoE power per port, PoE prioritization, PoE power limit per port and more. Simplifies management of PoE powered devices
UNINTERRUPTED PoE
Keep PoE power on even when the switch is updating firmware or performing a software reboot
5 GIGABIT PORTS
Gigabit connection delivers up to 1000 Mbps of dedicated, non-blocking bandwidth per port
FANLESS & VERSITILE MOUNTING
Completely silent operation within a desktop small form factor, and also wall-mountable
NON-BLOCKING SWITCHING
10Gbps (10/100/1000 Mbps) line rate fabric for great connectivity to your devices without congestion
COST-EFFECTIVE
Businesses do not necessarily have budget or advanced network training to deal with complex managed switches, the GS305EP offers affordable management features for a small additional cost above an Unmanaged switch
Tech-Specs-Image-1
Tech-Specs-Image-2
  • Dimensions (W x D x H) : 158 x 101 x 27 mm (6.2 x 4.0 x 1.1 in)
  • Weight : 0.39 kg (0.86 lb)
  • Speed : Gigabit
  • Total PoE+ Ports : 4
  • Total PoE+ Budget : 63W
  • Uninterrupted PoE : Yes
  • Bandwidth : 10Gbps
  • Max Mac Entries : 4K
  • Buffer Size : 192KB
  • Energy Efficient Ethernet (IEEE 802.3az) : Yes
  • Priority Queuing : WRR
  • Jumbo Frame Support : 9,216 bytes
    • Warranty: This product is backed by a NETGEAR limited lifetime hardware warranty (depending on region). Click here for coverage, availability and terms and conditions.
    • Optional Next Business Day Hardware Replacement for duration of warranty (depending on region). Click here for coverage, availability and terms and conditions.
    • Support: ProSUPPORT 24x7 Advanced Technical Support via phone for 90 days (Remote diagnostics performed by our technical experts for prompt resolution of technical issues). ProSUPPORT coverage can be extended by purchasing 1, 3, or 5-year contracts.
    • GS305EP Support
