How to Purchase and Activate a NETGEAR eSIM for Your M7 Hotspot
Getting your hotspot connected with a NETGEAR eSIM is quick and straightforward. Whether you’re setting up your M7 hotspot router for the first time or adding a new WiFi plan for an upcoming trip, the hotspot and NETGEAR app will guide you step by step, from choosing a plan to activating it when you’re ready.
Purchasing a NETGEAR eSIM in the NETGEAR mobile app is the fastest way to connect your Nighthawk M7 mobile hotspot to high-speed WiFi in 140+ countries.
The process is fast, fully digital, and designed to get your hotspot online in minutes with Gbps speeds.
Tech savvy travelers choose NETGEAR eSIM for:
Instant activation without the need for a physical SIM card
Global coverage across 250+ networks in 140+ countries
Flexible plans you can switch anytime
Networking with laptops, phones, and other connected devices, without the dangers of public WiFi
Here’s how it works:
Step 1: Open the NETGEAR eSIM Marketplace in the NETGEAR App
You can access the NETGEAR eSIM Marketplace in the app in any of the following ways:
From the main app Dashboard, tap Buy an eSIM.
From your device dashboard, tap Get a NETGEAR eSIM.
During first-time setup, tap Get a NETGEAR eSIM when prompted.
Step 2: Choose a Region or Country Where You will Use The eSim
NETGEAR eSIM plans are region-based, which means:
You can search by country for convenience
Your plan will be labeled by the region it covers (for example, Europe)
Step 3: Choose Your Data Plan
Plans range from 1GB to 20GB. The plan you choose will depend on the length of your trip and how you’ll be using WiFi. For example, streaming video uses more data than browsing the web.
Once you’ve chosen a plan, tap Checkout to continue and follow the touchscreen instructions to complete your purchase.
Step 4: Choose When to Use Your eSIM
After purchase, the app will automatically begin saving the eSIM to your M7, which may take up to a minute. Once the eSIM has been saved, you can choose whether to use your eSIM immediately, or save it for use at a later date.
If you choose “Use eSIM Now,” your eSIM will activate immediately, but it will only connect once you’re physically in the country or region covered by your plan.
You’re now ready to travel with your M7 hotspot fully equipped for seamless connectivity. Whether you’re heading abroad or staying local, your NETGEAR eSIM ensures you’re always online with secure, high-speed internet.
Monitoring, Managing and Switching eSIMs
If you have eSIMs saved on your M7, you can activate or switch between them at any time by tapping on My SIMs on your device dashboard. It’s easy to manage a Nighthawk M7 Pro or other elite NETGEAR hotspot with seamless connectivity while on the go. Plus, with NETGEAR eSIM you’ll get fast, reliable WiFi without any hidden roaming fees.
M7 Security Features
NETGEAR Nighthawk Mobile Hotspot security features are robust and continually updated, including firmware and firewall systems, plus the latest WPA3 encryption. You can trust NETGEAR security, powered by Qualcomm Snapdragon chipsets for real-time protection against hackers and cybercrime.
Consider M7 Hotspot Accessories
Take your NETGEAR Hotspot experience to the next level of excellence by including Nighthawk M7 accessories such as the Nighthawk Mobile Hotspot Cradle for travel convenience, a Mobile Fast Charger for maximum battery life, or a USB-C to Ethernet Adapter for dedicated high-speed Ethernet port wired connectivity. Nighthawk Portable WiFi Hotspots are robust companions ready for adventure, wherever your travels may take you.
Network operators and wireless providers such as AT&T and T-Mobile support NETGEAR mobile hotspot initiatives designed to deliver faster speeds, better connections, and stronger security protocols almost anywhere in the world.
Find your WiFi style with NETGEAR—the trusted American WiFi brand for Mobile Hotspot Routers, WiFi 7 Routers, and Whole-Home Mesh WiFi Systems.
