Holiday Travel WiFi: Nighthawk M7 Hotspot vs Phone Hotspot
Holiday travel comes with enough surprises. Your internet connection shouldn't have to be one of them.
Between checking flight updates at the airport, joining a last-minute work call, keeping the kids entertained during a layover, and connecting your laptop at the hotel, reliable WiFi can make a big difference.
Your smartphone's personal hotspot might seem like the easiest solution. But when multiple devices need internet access throughout a long travel day, relying on your phone isn't always practical.
That's where portable WiFi for travel comes in.
NETGEAR Logo White Black Background
WRITTEN BY
NETGEAR Team
  • Last Updated: November 24th, 2026
A dedicated 5G hotspot, such as the NETGEAR Nighthawk M7 (MH7150), uses its cellular data connection to create its own WiFi network without relying on your phone as the primary hotspot. But do you really need a separate device for your next holiday trip? Let’s compare the two options and help you decide.
Phone Hotspot vs Portable WiFi for Travel: What's the Difference?
A phone hotspot and a dedicated mobile hotspot work similarly: both share a cellular internet connection with other devices over WiFi.
The difference is how they handle that connection.
Your phone hotspot is convenient for occasional use. You can enable it in your phone’s settings and connect a laptop or tablet without purchasing additional hardware.
A dedicated travel hotspot, such as the Nighthawk M7, is designed specifically to provide internet on the go. The hotspot includes its own power supply, data connections, and WiFi network, not the device itself.
Here’s how they compare:
Feature Phone Hotspot Nighthawk M7 (MH7150)
Best for Occasional, short connections Frequent travel, families, remote work
Internet source Your phone’s cellular plan Compatible 5G/4G SIM or eSIM data plan
Device connections Varies by phone and carrier Up to 32 devices
Battery Uses your phone battery Dedicated battery, up to 10 hours
WiFi technology Depends on phone model WiFi 7
Network security Password-protected personal network WPA3, built-in firewall, automatic firmware updates
International travel Depends on roaming and phone plan Physical SIM and eSIM options, including NETGEAR international plans
Additional cost Usually no separate hardware purchase Hotspot purchase plus applicable data-plan costs
The short answer: If you don’t need regular connectivity with your laptop, a mobile hotspot should work. However, if you travel with many other devices or require constant connectivity, then the Nighthawk M7 will suit you better.
Not sure whether to use your phone’s hotspot, public WiFi, or a dedicated travel hotspot? Watch this video to learn how they compare and when a portable hotspot makes sense.
Why a Dedicated 5G Hotspot Makes Sense for Holiday Travel
1. Keep Your Phone Battery Available When You Need It
Picture this: You’re about to board the plane, but your phone battery is dead because you’ve been sharing its hotspot with your laptop.
The gate agent asks for your boarding pass, but your phone won’t turn on. Now you’re scrambling for a charger as boarding continues. Sharing your cellular connection can drain the battery, especially during long sessions. You may also need your phone for directions, messages, or rideshare pickups when you land.
The Nighthawk M7 has its own rechargeable battery, rated for up to 10 hours of use under specified conditions.
Instead of relying on your smartphone for WiFi all day, you can let the M7 handle the connection while keeping your phone available for other travel essentials. Actual battery life varies with network conditions, connected devices, and usage.
2. Connect More Devices Without Relying on One Phone
Holiday trips rarely involve just one connected device. You might be traveling with a laptop, tablet, smartphone, and handheld gaming console. Add a partner or children, and the number of devices grows quickly. The Nighthawk M7 supports up to 32 connected devices simultaneously.
That makes it a practical option for:
  • Families traveling with several phones, tablets, and laptops
  • Remote workers using multiple connected devices
  • Couples sharing one dedicated travel hotspot
  • Small groups who need access to the same WiFi network
Instead of asking one person to keep their phone’s hotspot enabled, travelers can connect their devices directly to the M7’s password-protected network.
Enabling the connection of 32 devices does not necessarily mean all of them can receive maximum speed simultaneously, since cellular bandwidth is shared among connected devices.
3. Get WiFi 7 Connectivity Powered by 5G
Slow connections can be frustrating when you’re trying to download a boarding pass, upload work files, or stream entertainment during a long hotel stay.
The Nighthawk M7 combines a 5G/4G cellular connection with WiFi 7 technology.
It supports theoretical WiFi speeds of up to 3.6 Gbps, giving compatible devices access to a high-performance local wireless network.
However, there’s an important distinction: WiFi speed isn’t the same as internet speed.
Your actual download and upload speeds depend on factors such as:
  • 5G or 4G signal strength
  • Carrier coverage and network congestion
  • Your selected data plan
  • The number of connected devices
  • Building materials and the surrounding environment
Not all designated hotspots outperform other modern smartphones. However, the M7, which has been designed specifically to perform that function, with WiFi 7 and multiple device connectivity abilities, is an excellent choice for those who travel often.
4. Use Your Own WiFi Network at Airports and Hotels
Public WiFi is convenient, particularly if it comes with an airport lounge membership or hotel reservation. However, the quality of service may vary greatly from one location to another. In a hotel, each device will need a unique login. In the case of airports, the quality of service can decrease due to heavy use by other passengers.
Using the Nighthawk M7 with an active cellular data plan gives you another option. The M7 creates a password-protected WiFi network with features including WPA3 encryption, a built-in firewall, and automatic firmware updates. This gives you greater control over the network your devices use, rather than relying entirely on a venue’s public WiFi.
Important: Public WiFi isn’t inherently unsafe, and HTTPS encryption already protects much of today’s web traffic. A private hotspot also doesn’t eliminate every online security risk.
Still, having a network you manage yourself can be especially useful when you’re traveling with multiple devices or handling work online.
Airport, Hotel, or Road Trip: When Is the M7 Worth Bringing?
Not every trip requires a dedicated hotspot. Here are a few common holiday travel situations where the difference becomes clearer.
At the Airport: Long Layovers and Flight Delays
You have some time between flights and need to send a couple of emails on your laptop.
Phone hotspot: A viable option, given that your connection is temporary and you’re traveling solo.
Nighthawk M7: A good alternative, especially when you have some layover time, are working with different devices, or need to use your internet connection with family.
With the M7, your phone stays available while other devices use the dedicated hotspot.
At the Hotel: Work, Streaming, and Multiple Devices
You’ve checked into your hotel, but the complimentary WiFi is congested or keeps asking you to sign in again.
Phone hotspot: This can serve as an emergency backup in case your cellular plan has enough data for a hotspot.
Nighthawk M7: Provides a separate option for connecting your laptop, tablet, and other gadgets via a single network.
The M7 can be particularly useful when you need an independent cellular connection for video meetings or other important online activities.
Just remember that indoor cellular coverage varies. Thick walls, the hotel’s location, and carrier signal strength can all affect performance.
On a Family Road Trip: Keeping Everyone Connected
Traveling by road during holidays could mean many hours of travel from one point to another.
One may need to stream music, another may need navigation systems, while others might want to use their tablets or gaming devices.
Phone hotspot: Could suffice when traveling with a few devices for a short while.
Nighthawk M7: Offers its own network where everyone could make use of it without having to rely on a phone. A very useful tool for people traveling with many internet-connected gadgets.
There is still no coverage in certain places, and streaming from many devices uses data quickly.
Traveling Internationally? Consider Your Data Plan Before You Go
One of the biggest challenges with portable WiFi for travel isn’t necessarily the device. It’s getting the right mobile data plan.
An unlocked hotspot provides carrier flexibility, but unlocked doesn’t mean every SIM card or data plan will work automatically.
The Nighthawk M7 (MH7150) supports both physical SIM cards and eSIM technology, providing different ways to connect at home and abroad.
Through the NETGEAR app, travelers can purchase eligible eSIM data plans with coverage options spanning more than 140 countries.
You can also use a compatible third-party eSIM or physical SIM, subject to carrier support and activation requirements.
How to Prepare Your Nighthawk M7 Before Traveling
  1. Check coverage at your destination. Confirm that an available carrier or eSIM plan supports the country or region you’re visiting.
  2. Choose a suitable data plan. Consider how many devices will connect and whether you’ll be browsing, streaming, or working remotely.
  3. Set up the M7 in advance. Download the NETGEAR app, complete the device setup, and configure your eligible SIM or eSIM.
  4. Confirm activation and compatibility. Some carriers require a dedicated hotspot plan or specific device activation procedures.
  5. Test your connection before departure. Make sure your devices connect successfully, so you’re not troubleshooting for the first time at the airport.
For step-by-step guidance, see How to Purchase and Activate a NETGEAR eSIM for Your M7 Hotspot.
Important: A mobile hotspot will need to have an appropriate data service that allows internet connectivity. These vary depending on the carrier and location where you travel to.
Is a Dedicated Travel Hotspot Worth the Extra Cost?
Before buying portable WiFi for travel, consider how often you’ll actually use it.
A phone hotspot usually has the advantage of convenience. You already own the device, and tethering may be included in your existing mobile plan.
The Nighthawk M7 requires an additional hardware purchase, plus an eligible cellular data plan.
That makes it easier to justify for travelers who regularly need internet access across multiple devices than for someone who only tethers a laptop for a few minutes each month.
Here’s a simple way to decide:
Stick with your phone hotspot if:
  • You travel occasionally.
  • You usually connect only one additional device.
  • Your phone plan includes sufficient hotspot data.
  • Your connection needs are brief or infrequent.
Consider the Nighthawk M7 if:
  • You travel frequently for work or leisure.
  • You want to keep your phone battery available.
  • You regularly connect several devices.
  • You travel internationally and want physical SIM and eSIM flexibility.
  • You prefer a dedicated, password-protected network instead of depending entirely on public WiFi.
It may be a worthwhile expense to have a hotspot, but the best decision will depend on you and your individual needs and preferences.
Frequently Asked Questions About Portable WiFi for Travel
Is a portable WiFi hotspot better than using my phone?
This will be determined by the manner in which you travel. A mobile phone hotspot can do, but for a more extended period of time and for different devices, a separate hotspot will be required; for example, the Nighthawk M7 hotspot has its own battery.
Does the Nighthawk M7 need a SIM card or data plan?
Yes. To access the internet over a cellular network, the M7 requires an active, compatible physical SIM or eSIM data plan. The hardware purchase does not automatically include unlimited mobile data.
How many devices can connect to the Nighthawk M7?
The number of devices that can be connected through the Nighthawk M7 at once is 32. The efficiency of the process will depend on the cellular connection and the chosen plan.
Can I use the Nighthawk M7 internationally?
But yes, this is possible when you travel to supported locations with a suitable data plan. The M7 offers the ability to use a physical SIM or eSIM and NETGEAR eSIM services in over 140 countries.
Is a 5G hotspot faster than a phone hotspot?
Not necessarily. There is potential to benefit from a 5G hotspot when it comes to device control, battery freedom, and wireless networking; however, internet speed will still depend on many factors.
Can I use a mobile hotspot instead of hotel WiFi?
Indeed, as long as there is adequate cellular service and your data plan is on. The mobile hotspot would be a handy option to use when WiFi internet connection is slow or difficult to access.
Make Holiday Travel Easier with the Nighthawk M7
Whether it is traveling by air, at a hotel check-in, or on a family road trip, staying connected should not entail the constant fear of running out of your phone’s battery.
For occasional travelers, your smartphone’s hotspot feature could be sufficient.
However, for travelers who will be using their gadgets frequently during their holidays, having a dedicated travel hotspot would provide much more freedom.
The NETGEAR Nighthawk M7 (MH7150) brings together 5G connectivity, WiFi 7, supports WiFi up to 32 devices, up to 10 hours of battery life, and SIM/eSIM options in a portable design.
Before your next trip, make sure you have the right connection for the journey.
Explore the NETGEAR Nighthawk M7 Portable WiFi Hotspot
ProWiFi performance, battery life, coverage, and data-plan availability vary by network, carrier, environment, and usage. Check current specifications and carrier compatibility before purchase.
