Introducing the M7 Portable WiFi Hotspot: Your Passport to 5G WiFi Freedom
Freedom to conveniently connect anywhere and everywhere is now a reality thanks to the Nighthawk M7 Portable WiFi Hotspot. Live and work with uncompromised performance courtesy of powerful WiFi 7 and experience true mobility that users demand and only NETGEAR can deliver.
NETGEAR Logo White Black Background
WRITTEN BY
NETGEAR Team
Global Connectivity, Unbound
Imagine having your own high-speed portable WiFi network wherever you are, without the constraints of unreliable public WiFi and physical SIM cards. The Nighthawk 5G M7 overcomes the limitations of public WiFi by providing a secure, high-speed connection wherever you go, ensuring seamless performance for work, travel, and entertainment. This marks a new era of global WiFi connectivity, designed to keep up with the demands of modern life without the constraints of the past.
The Power of WiFi 7 in Your Palm
The Nighthawk 5G M7 Portable WiFi Hotspot, also known as the Nighthawk 5G M7 Portable WiFi Hotspot with eSIM model MH7150, puts the power in the palm of your hand to deliver unprecedented mobile WiFi speed with lower latency and the ability to handle dozens of devices simultaneously without a drop in performance. Real-world M7 capability includes flawless 4K streaming, lag-free video calls, and rapid file downloads.
WiFi 7 enhances the M7’s ability to deliver ultra-fast, low-latency connections to multiple devices, complementing its 5G capabilities for a superior mobile experience.
Blazing Speeds for Work, Play, and Everything in Between
Are you looking for next-generation speed? How does 5G Sub-6 with up to 4 Gbps and aggregated WiFi 7 speeds up to 3.6 Gbps sound? Nighthawk 5G M7 performance provides the ability to go anywhere, stay connected, and accomplish anything with seamless flexibility. That’s ultimate freedom only a NETGEAR WiFi 7 portable mobile hotspot can deliver.
More Devices, Zero Compromises
Imagine a world where staying connected is effortless, no matter where you are. The M7 provides up to 2,000 sq. ft. of coverage and supports up to 32 devices, making it the ultimate solution for modern connectivity. From working remotely in a serene mountain cabin to streaming your favorite content in a crowded airport or managing a pop-up shop in a busy urban setting, the M7 empowers you to achieve more. With its robust performance, you can enjoy seamless internet access for work, entertainment, and everything in between.
Reimagine What’s Possible with the M7
Almost anything online is possible with M7 WiFi connectivity. Working from a mountain cabin is a breeze, as is streaming in a busy airport, running a pop-up shop anywhere, or getting digitally creative with real-time imagination. The potential is unlimited.
netgear esim marketplace m7
What is eSIM Instant Connectivity?
eSIM (embedded SIM) is a digital version of the traditional SIM card and a key technology feature of Nighthawk M7 mobile hotspots. Unlike a removable SIM card, an eSIM is embedded into the hotspot at the factory. It’s a genuine game-changer for travelers and professionals.
Your NETGEAR eSIM connects instantly to the strongest available local network, across 250+ providers worldwide. Setup takes just minutes, and with the NETGEAR app you can track usage, purchase plans on the go, and manage your plan with ease. No physical SIM cards, no contracts, no hidden fees, just private, reliable internet.
Your Global Data Plan, On-Demand
You can update or change your Nighthawk 5G M7 hotspot device plan over the air from the device app in over 140 countries. There’s no physical store visit required. Store several carrier profiles on one device and switch between them without swapping cards—ideal for frequent travelers.
Designed for Simplicity
NETGEAR Nighthawk 5G portable WiFi 7 mobile hotspots are designed for simplicity of use. The setup process is effortless and the NETGEAR app allows you to personally manage your mobile hotspot plan and monitor device usage from wherever you are.
Security You Can Trust, Anywhere in the World
High-functioning security is critical in today’s online world. The Nighthawk M7 helps you establish a personal, encrypted network for family, friends, or colleagues locally, nationally, or internationally, and protects sensitive data from the risks of public WiFi. NETGEAR is a trusted US-based company committed to user privacy and robust security.
Nighthawk 5G M7 Features and Benefits in a Nutshell
  • Nighthawk 7 5G mobile hotspot with eSIM Cutting-edge WiFi 7 meets best-in-class 5G technology with current and future 5G Sub6 capabilities for unmatched internet on-the-go.
  • Unlocked Potential: Accepts SIM cards and eSIMs from major 5G/4G network operators.
    Next-generation Dual-band WiFi 7: Game, stream, or video call with 4K quality with blazing fast multi-gigabit speeds for 32 devices.
  • Flexible connectivity for all your devices: Connection options for any device with WiFi 7 and backwards compatible with other WiFi versions. Tether with an onboard Multi-gig USB-C Port or use a USB-C to Ethernet Adapter (sold separately).
  • Home and travel flexibility: Unlock powerful WiFi anywhere you need it or plug in for high performance in your home or office.
  • Reliable internet anytime you need it: Up to 10 hours of battery life keeps you online, whether on-the-go or as a backup solution.
  • Set up and manage on the device or on the web: Use the 2.4” color LCD screen to change settings, signal strenth, battery percentage or access the powerful web interface for advanced configuration.
  • Qualcomm Snapdragon® X72 Modem: 5G Sub-6 SA/NSA support with up to 4 Gbps peak cellular speeds with 4G LTE CAT20 fallback with up to 2 Gbps peak cellular speeds.
  • Advanced Router Protecton: Built-in URL filtering, device blocking, and lets you protect your family and enjoy a safer online experience, anywhere life takes you.
Nighthawk M7 Hotspot Accessories
Enable LAN capabilities and passthrough charging with optional accessories designed for the M7 and other Nighthawk Hotspots.
nighthawk cradle md200
Home Cradle Accessory
Nighthawk Mobile Hotspot Cradle (MD200): Instant power and wired connectivity for your Nighthawk Mobile Hotspot.
  • Cooling Fan
  • USB Charging and connectivity ports
  • 2x 1Gb RJ45 Ethernet LAN Ports
  • Passthrough Charging
  • Plug & Play
usb2eth m7 laptop inline
USB-C to Ethernet Adapter Accessory
Nighthawk USB-C to Ethernet Adapter (USB2ETH): The Nighthawk USB-C to Ethernet Adapter provides a seamless way to enhance LAN connectivity for your compatible Nighthawk mobile hotspot.
  • 1x 1Gb RJ45 Ethernet LAN Port
  • Plug & Play
m7 fast charger mhpadpt
Fast Charger
Nighthawk® Mobile Fast Charger (MHPADPT): The Nighthawk Mobile Fast Charger is a powerful and efficient charging solution for your Nighthawk Mobile Hotspot or other USB-C devices.
  • Max power: 27 W
  • Plug & Play
  • Worldwide power sockets include with product. (Datasheet)
Experience Unmatched Connectivity with the Nighthawk M7
The Nighthawk 5G M7 Portable WiFi Hotspot with eSIM redefines what it means to stay connected, offering unparalleled speed, security, and flexibility for life on the go. Whether you’re a security conscious digital nomad, frequent traveler, or mobile worker seeking seamless connectivity, the M7 empowers you to work, play, and explore without limits. Don’t settle for unreliable and unsecure public WiFi—experience the freedom of your own high-speed, secure network anywhere in the world. Preorder Now.
FAQs
What is the Nighthawk 5G M7 Portable WiFi Hotspot with eSIM​?
The NETGEAR M7 Portable WiFi Hotspot (also known as the M7 or MH7150) is a high-performance mobile hotspot router that combines 5G connectivity with next-generation WiFi 7 technology to deliver ultra-fast, secure internet access on the go.
How is a WiFi 7 mobile hotspot better than a traditional 5G hotspot?
WiFi 7 mobile hotspots offer significantly faster speeds, lower latency, and better multi-device performance compared to traditional 5G hotspots. This is especially noticeable in dense environments or for high-bandwidth tasks.
What is an eSIM mobile hotspot and how does it work?
An eSIM mobile hotspot offers cellular data digitally without needing to install a physical SIM card. It uses an embedded SIM for seamless network integration and instant connectivity.
Can I use the Nighthawk 5G M7 anywhere in the world?
The M7 is a global capable WiFi hotspot designed to work with 5G networks in the in 140+ countries, it supports a wide range of 5G Sub-6 bands used internationally. The M7 series is considered among the best mobile hotspots for travel on the market.
Is the Nighthawk 5G M7 secure for business use?
Yes, the Nighthawk 5G M7 is secure for business use. It offers robust encryption, supports up to 32 devices, and integrates advanced WiFi 7 and 5G technologies to ensure fast, reliable, and protected connectivity. It includes Advanced Router Protecton with built-in URL filtering, device blocking, and lets you protect your devices and team, enjoying a safer online experience, anywhere work takes you.
Who will benefit from owning a Nighthawk 5G M7 mobile hotspot?
Everyone will benefit, and the technology is particularly attractive to tech-savvy professionals, frequent travelers (for business and leisure), remote workers, digital nomads, and families who require reliable, high-speed internet on the go.
