48-Port Gigabit Ethernet Unmanaged Switch
GS748
gs748_front_tipoff
  • 48 Ports
Port Types
  • 48 x 10/100/1000 Mbps Ports (Auto Uplink)
48 x Gigabit Ethernet ports Plug and play switch, no management required Energy Efficient Ethernet for maximum power savings Fanless and silent Rackmount or desktop
Download GS748 Datasheet
GS748
48 Ports • 1G
  • 48 Ports
Port Types
PLUG-AND-PLAY
Simple set up with no software to install or configuration needed
NON-BLOCKING SWITCHING
FANLESS DESIGN
VERSATILE MOUNTING OPTIONS
Place your switch on your desktop or mount it to your rack with the hardware provided in the box
ENERGY EFFICIENT
QUALITY AND RELIABILITY
Peace of mind with limited lifetime warranty, next business day replacement*, and lifetime email and chat support.
Product Datasheet
Product Specifications
Dimensions (W x D x H) :
440 x 202 x 43 mm (17.9 x 8.0 x 1.7 in)
Weight:
3.2kg (6.9 lb)
Speed:
1G
Number of Ports:
48
Number of PoE+ Ports:
0
Energy Efficient Ethernet Support (IEEE 802.3az):
Yes
Jumbo Frame Support:
9,216 bytes
MAC Table Size:
8K
Packet buffer size:
1.5MB
IEEE 802.1p QoS:
Yes
Max Power Consumption:
23W
Fans:
0
Operating Temperature:
0-50°C (32°F - 122°F)
MTBF (hours)
1,094,297 hours (125 years)
FCC Class
Class A
Warranty :
Support :
High Resolution Images
Low Resolution Images
