24-Port Gigabit Ethernet Unmanaged Switch
GS524
GS524_Unmanged Switches
  • 24 Ports
Port Types
  • 24 x 10/100/1000Mbps Ethernet RJ-45 ports
PoE Budget
  • n/a
24 x Gigabit Ethernet ports Energy Efficient Ethernet for maximum power savings Fanless and silent Desktop, wall or rack mount
Download GS524 Datasheet
GS524
24 Ports • 1G
  • 24 Ports
Port Types
PoE Budget
  • n/a
RELIABLE PERFORMANCE
Superior network performance at non-blocking rate delivers true gigabit speed with no compromise
ENERGY EFFICIENT
PLUG-AND-PLAY
No software to install. No configuration needed. Zero maintenance required
SILENT OPERATION
VERSATILE MOUNTING OPTIONS
Install your switch on your desktop, mount it to your wall, or add it to a standard 19 inch (44 mm) rack with the hardware provided in the box
METAL CASE
Durable and rugged case for long-lasting performance
Product Datasheet
Dimensions (WxDxH)
328 x 169 x 43 mm (12.9 x 6.7 x 1.7in)
Weight
1.47kg (3.24lb)
Speed
10/100/1000Mbps Gigibit Ethernet
Number of Ports
24
PoE ports
n/a
Total PoE Budget
n/a
Loop Detection
n/a
Short cable power saving
Yes
Yes
Jumbo Frame Support
9KB
Queue WRR Ratio
1:2:4:8
MAC Table Size
8K
Packet buffer size
512.5KB
IEEE 802.1p QoS
Yes
Max Power Consumption
12W
Operating Temperature
0 to 50° C
MTBF (hours)
1,016,877 hrs
FCC Class
A
Warranty
Support
NETGEAR Support offers a customizable support experience based on your operational needs:
High Res Images
Low Res Images
Installation Guide
