16-Port Gigabit Ethernet Unmanaged Essentials Switch
GS316
gs316v3
1 / 5
  • 16 Ports
Port Types
  • 16 x 10/100/1000Mbps Ports (Auto Uplink)
NETGEAR Essentials Switches featuring 16 ports of gigabit Ethernet. This switch is plug-and-play requiring no extra setup. It’s durable, energy-efficient and rigorously tested delivering reliable performance.
Download GS316 Datasheet
GS316
16 Ports • 1G
  • 16 Ports
Port Types
PLUG-AND-PLAY
Simple set up with no software to install or configuration needed
FULL PERFORMANCE
FANLESS DESIGN
VERSITILE MOUNTING OPTIONS
Install your switch on your desktop or mount it to your wall with the hardware provided in the box
ENERGY EFFICIENT
Product Datasheet
Dimensions (WxDxH)
286 x 102 x 27 mm (11.3 x 4.0 x 1.1 in)
Weight
0.89 kg (1.96 lb)
Speed
Gigabit
Number of Ports
16
Yes
Jumbo Frame Support
9 KB
MAC Table Size
8 K
Packet buffer size
512 KB
IEEE 802.1p QoS
Yes
Max Power Consumption
8.1 W
Operating Temperature
0-50° C (32° F - 122° F)
MTBF (hours)
4,160,957 hours (475 years)
FCC Class
Class A
Warranty
Support
High Resolution Images
Low Resolution Images
DatasheetInstallation Guide
