5-Port Gigabit Ethernet Unmanaged Essentials Switch
GS305
1 / 9
  • 5 Ports
Port Types
  • 5 x 10/100/1000Mbps Ports (Auto Uplink)
PoE Budget
  • N/A
Get networks up and running with plug-and-play unmanaged switches. Set it and forget it, energy-efficient switches are built like tanks and last for decades.
Download GS305 Datasheet
GS305
5 Ports • 1G
  • 5 Ports
Port Types
PoE Budget
  • N/A
PLUG & PLAY: Simple setup with no software or configuration needed.
FLEXIBLE MOUNTING: Mount on desktop, or wall.
SMALL SIZE, METAL CASE, AND SILENT OPERATION: Durable quality, space saver, and quietness for peace of mind.
Product Datasheet
Dimensions (W x D x H)
101 x 94 x 29 mm (4.0 x 3.7 x 1.1 in)
Weight
0.24 kg (0.53 lb)
Model Description
NETGEAR 5-Port Gigabit Ethernet Unmanaged Essentials Switch (GS305v3)
Speed
Gigabit
Number of Ports
5
Connector Type
Metal
Switch Housing
Metal
LEDs
Power, Link/Activity
Short cable power saving
Yes
Yes
Jumbo Frame Support
9,216 bytes
MAC Table Size
2K
Packet buffer size
128 KB
DC Power Adapter
5V / 0.7A
Max Power Consumption (Watts)
2.34W
Acoustic Noise Level @ 25° C (dBA)
0 dBA (Fanless)
Operating Temperature
0° to 40°C (32° to 104°F)
MTBF (@ 25° C)
3,670,230 hours
Electromagnetic compliance (A or B)
Class B
Form Factor
Desktop or wall-mountable
Warranty
Support
Low Resolution
High Resolution
Installation Guide
