8-Port Gigabit Ethernet Unmanaged Switch with 1 dedicated 10G/Multi-Gig Port
GS108MX
CMS_Tech_Specs_Image-GS108MX_Shadow_s.Front_left1
  • 8 Ports
Port Types
  • 8 x Gigabit Copper Ports
  • 1 x 10G/Multi-Gig Port
8 x Gigabit Ethernet ports 1 x 10G/Multi-Gig port Energy Efficient Ethernet for maximum power savings Fanless and silent Desktop or wall-mount
Download GS108MX Datasheet
GS108MX
8 Ports • 1G
  • 8 Ports
Port Types
PLUG-AND-PLAY
Simple set up with no software to install or configuration needed
FULL PERFORMANCE
SILENT OPERATION
ENERGY EFFICIENT
Designed to optimize power usage lowering its cost to operate
METAL CASE
Durable and rugged case for long-lasting performance
VERSATILE MOUNTING OPTIONS
Supports desktop and wall placement with included wall-mount kit
Product Datasheet
NETGEAR GS108MX Unmanaged Switch
Power adapter (varies by region)
Wall-mount kit
Installation guide
Rubber feet
Width
236mm (9.3in)
Depth
101mm (4.0in)
Height
27mm (1.1in)
Weight
1.26lb (0.58kg)
Gigabit copper ports
8
Uplink port
Max MAC entries
16K
Buffer size
768Kbit or 0.75Mbit
EEE
Yes
Internal/External Power Supply/Adapter
External Power Adapter
Max power consumption (worst case. all ports used, line-rate traffic)
5.8W
Fans
0
Acoustic Noise Level @25C
0 dBA
Operating Temperature
0° to 40° C (32° to 104°F)
MTBF
3,514,690 hrs (401 yrs)
Warranty :
Support :
High Resolution Images
Low Resolution Images
DatasheetInstallation Guide
We're Always Here to Help
Visit my.netgear.com
