16-Port Gigabit Ethernet Easy Smart PoE+ Switch with 1 Dedicated SFP port (231W)
GS116EPP
CMS_Tech_Specs_Image-GS116EPP_P_Shadow_Front_left1
1 / 5
  • 16 Ports
Port Types
  • 16 x 10/100/1000 RJ45 Copper Ports (Auto Uplink)
  • 15 x PoE+ 802.3at Ports
  • 1 x SFP fiber ports
PoE Budget
  • Up to 231W
15 x Gigabit Ethernet ports with PoE+ with 1 SFP Fiber port Plug-and-play with fundamental network management features QoS and VLAN management Energy Efficient Ethernet for maximum power savings Fanless and silent Desktop or wall-mount
Download GS116EPP Datasheet
GS116EPP
16 Ports • 15 PoE+ • 1G • up to 231 W
  • 16 Ports
Port Types
PoE Budget
  • Up to 231W
EASY POE CONTROLS
Manage PoE prioritization, PoE power limit per port, PoE scheduling and more for advanced control over all PoE-powered devices
GIGABIT ETHERNET AND FIBER
15 ports provide Gigabit Ethernet connectivity to your devices and 1 SFP fiber port for long distance connections
VLANS
FANLESS DESIGN
VERSATILE MOUNTING OPTIONS
Place your switch on your desktop or mount it to your wall with the hardware provided in the box. Silent operation makes this switch perfect for noise-sensitive environments
ENERGY EFFICIENT
Product Datasheet
Dimensions (W x D x H)
286 x 101 x 27 mm (11.3 x 4.0 x 1.1 in)
Weight
0.83kg (1.83 lb)
Speed
1G
Number of Ports
16
Number of PoE+ Ports
15
PoE Power per Port
Up to 30
PoE Budget
Up to 231W
Yes
Jumbo Frame Support
10,000 bytes
MAC Table Size
8K
Packet buffer size
4.1MB
IEEE 802.1p QoS
Yes
Max Power Consumption
250.6W
Operating Temperature
0-40°C (32°F - 104°F)
MTBF (hours)
570,4358 hours (61 years)
FCC Class
Class B
Warranty :
Support :
High Resolution Images
Low Resolution Images
DatasheetInstallation GuideUser Manual
