8-Port Gigabit Ethernet Easy Smart PoE+ Switch (62W)
GS108EP
CMS_Tech_Specs_Image-GS108EP_Shadow_P_Front_left1
  • 8 Ports
Port Types
  • 8 x 10/100/1000 RJ45 Copper Ports (Auto Uplink)
  • 8 x PoE+ 802.3at Ports
  • 0 x SFP fiber ports
PoE Budget
  • Up to 62W
8 x Gigabit Ethernet ports with PoE+ Plug-and-play with fundamental network management features QoS and VLAN management Energy Efficient Ethernet for maximum power savings Fanless and silent Desktop or wall-mount
Download GS108EP Datasheet
GS108EP
8 Ports • 8 PoE+ • 1G • up to 62 W
  • 8 Ports
Port Types
PoE Budget
  • Up to 62W
EASY POE CONTROLS
Manage PoE prioritization, PoE power limit per port, PoE scheduling and more for advanced control over all PoE-powered devices
GIGABIT ETHERNET
8 ports provide gigabit Ethernet connectivity to your devices
VLANS
FANLESS DESIGN
VERSATILE MOUNTING OPTIONS
Place your switch on your desktop or mount it to your wall with the hardware provided in the box. Silent operation makes this switch perfect for noise-sensitive environments
ENERGY EFFICIENT
Product Datasheet
Dimensions (W x D x H)
158 x 101 x 27 mm (6.2 x 4.0 x 1.1 in)
Weight
0.49kg (1.08 lb)
Speed
1G
Number of Ports
8
Number of PoE+ Ports
8
PoE Power per Port
Up to 30
PoE Budget
Up to 62W
Yes
Jumbo Frame Support
9,216 bytes
MAC Table Size
4K
Packet buffer size
1.5MB
IEEE 802.1p QoS
Yes
Max Power Consumption
74.4W
Operating Temperature
0-40°C (32°F - 104°F)
MTBF (hours)
859,126 hours (98 years)
FCC Class
Class B
Warranty
Support
High Resolution Images
Low Resolution Images
DatasheetInstallation GuideUser Manual
