5-Port Gigabit Ethernet Easy Smart High-Power PoE+ Switch (120W)
GS105EPP
  • 5 Ports
Port Types
  • 5 x 10/100/1000 RJ45 Copper Ports (Auto Uplink)
  • 4 x PoE+ 802.3at Ports
  • 0 x SFP fiber ports
PoE Budget
  • Up to 120W
5 x Gigabit Ethernet ports with 4 x PoE+ ports Plug-and-play with fundamental network management features QoS and VLAN management Fanless and silent Desktop or wall-mount
Download GS105EPP Datasheet
GS105EPP
5 Ports • 4 PoE+ • 1G • up to 120 W
  • 5 Ports
Port Types
PoE Budget
  • Up to 120W
Features and benefits
EASY POE CONTROLS
Manage PoE prioritization, PoE power limit per port, PoE scheduling and more for advanced control over all PoE-powered devices
GIGABIT ETHERNET
5 ports provide gigabit Ethernet connectivity to your devices
VLANS
FANLESS DESIGN
VERSATILE MOUNTING OPTIONS
Place your switch on your desktop or mount it to your wall with the hardware provided in the box. Silent operation makes this switch perfect for noise-sensitive environments
ENERGY EFFICIENT
Product Datasheet
Dimensions (W x D x H) :
158 x 101 x 27 mm(6.2 x 4.0 x 1.1 in)
Weight :
0.40kg (0.88 lb)
Speed :
1G
Number of Ports :
5
Number of PoE+ Ports :
4
PoE Power per Port :
Up to 30
PoE Budget :
Up to 120W
Energy Efficient Ethernet Support (IEEE 802.3az) :
Yes
Jumbo Frame Support :
9,216 bytes
MAC Table Size :
2K
Packet buffer size :
192 kb
IEEE 802.1p QoS :
Yes
Max Power Consumption :
137.8W
Operating Temperature :
0-40°C (32°F - 104°F)
MTBF (hours) :
853,770 hours (97 years)
FCC Class :
Class B
Warranty :
Support :
High Resolution Images
Low Resolution Images
Become a Partner
