48-Port Gigabit Ethernet Unmanaged Essentials Switch
GS348
1 / 7
  • 48 Ports
Port Types
  • 48 x 10/100/1000Mbps Ports (Auto Uplink)
Get networks up and running with plug-and-play unmanaged switches. Set it and forget it, energy-efficient switches are built like tanks and last for decades.
Download GS348 Datasheet
GS348
48 Ports • 1G
  • 48 Ports
Port Types
PLUG & PLAY:
Simple setup with no software or configuration needed.
FLEXIBLE MOUNTING:
Mount on rack or desktop
SMALL SIZE, METAL CASE, AND SILENT OPERATION:
Durable quality, space saver, and quietness for peace of mind.
LIFETIME LIMITED WARRANTY & NEXT BUSINESS DAY REPLACEMENT:
NETGEAR has your back to ensure your network is up and running.
STURDY METAL CASE, DESKTOP/RACKMOUNT FORM FACTOR WITH QUIET FANS:
Can be placed on desk or on mounted rack and will operate quietly with assured durability.
Product Datasheet
Dimensions (W x D x H)
440 x 204 x 43.3 mm (17.3 x 8.0 x 1.7 in)
Weight
3.15 kg (6.94 lb)
Model Description
NETGEAR 48-Port Gigabit Ethernet Unmanaged Essentials Switch (GS348)
Speed
Gigabit
Number of Ports
48
PoE Ports / Max Power Per Port
n/a
PoE Max Power Supplied (All Ports)
n/a
Connector Type
Metal
Switch Housing
Metal
LEDs
Power, Speed, Link/Activity
Short cable power saving
Yes
Yes
Jumbo Frame Support
9,720 bytes
MAC Table Size
16K
Packet buffer size
1.5MB
Power
Internal (AC 110-240V, 50-60Hz, 1.0A max)
Max Power Consumption (Watts)
23W
Acoustic Noise Level @ 25° C (dBA)
0 dBA (Fanless)
Operating Temperature
0° to 50°C (32° to 122°F)
MTBF (@ 25° C)
Electromagnetic compliance (A or B)
Class A
Form Factor
Desktop, wall-mountable, or rack-mountable
Warranty
Support
Datasheet
Installation Guide
